Pular para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
1203 Perguntas Ver todas
Home Button and Touch ID not functioning
So I was doing a screen replacement on an iPhone 7 today. Have it a couple 30 second bursts of a hair dryer just to loosen the glue. Put my pry tool in and started to gently work on the bottom left hand side of the phone. I had the screen pretty much pried off when I accidentally hit the power button and the phone turned on, when it turned on I got a message saying that the power button needed servicing and the assistive touch thing came up on the screen. I continued with the repair, everything works perfectly apart from the home button. I have tried it on the old screen, not working there either.
I know logic says I did damage but I have looked and looked at the home button and ribbon cable and cannot see anything wrong with it. All I had done when I got this message was open the phone. I’m not a rookie with either, I have replaced upwards of 100 screens on lots of different iPhones. Am I goosed here?
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
Kit de Reparo de Bateria do MacBook
A partir de $69.99
Buy Now
A partir de $69.99
Buy Now
1 Solução
Solução escolhida
It’s pretty easy to tear the Home Button flex from the screen. It has a nice 90 degree turn that is ripe for tears. However, as an experienced tech, you would probably be able to spot that pretty easily. I just wonder if you didn’t accidentally damage the actual Home Button and it’s flex when you applied the pry tool. Stuff like that happens even to the best of us ;>).
Esta resposta foi útil?
Pontuação 1
Comentários:
Ugh anything is possible I guess, it’s not working for a reason and it’s driving me insane cause I don’t know what it is. I think I’m gonna stop it to my board guy to have a look at it under the microscope to see if he can see any damage anywhere. Painfully annoying, phone is pretty much worthless now.
por
Adicionar a sua resposta
Mary Ellen será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Todo: 39
