No luck with headphone flex cable replacement
Hello,
I seem to have no luck with replacing the headphone jack flex cable. Initial problem was a bad headphone jack but all other buttons worked fine (mute, volume, power).
All cables were bought from ebay:
1st cable: both volume buttons increase the volume. All other buttons ok.
2nd cable: no sound from the headphones but all buttons work.
3rd cable: both volume buttons increase the volume while the mute switch doesn't work.
Are these flex cables that finicky? I did reinstall the original cable and both volume buttons work normally which would rule out the logic board. Also some of the cables, the mute button doesn't seem to fit properly. Any advice or hints would be greatly appreciated. I've given up and just live with not being able to decrease the volume from the side buttons.
Esta é uma boa pergunta?
