iPhone won’t activate
I’m trying to activate my phone but I just get this screen
I have tried plugging into iTunes but that doesn’t work either
Esta é uma boa pergunta?
It seems the iPhone firmware is corrupted and it needs a factory restore. You will need a computer to perform that and since iTunes doesn’t manage to do it the standard mode you’ll have to put the iPhone into DFU first, https://www.theiphonewiki.com/wiki/DFU_M... . If you have no success and you have a windows based PC you can also try to do the job with http://www.3u.com/
Esta resposta foi útil?
I did that and still have the same issue
@pad Then I suspect somebody has put his hands into the iPhone trying to achieve some goal he didn't manage to. Just purchased from ?
so some problem with the board? bought of eBay not turning on replaced battery and dock connector
Quite sure it's a board problem, unsure what it might be, but it seems an identity problem, as if it was a frankenstein-ized board.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 64
1 comentário
What's the history on this phone?
por mayer
