camera won't work unless plugged into an outlet
My camera was dropped and now it won’t work. I can only turn it on if it is plugged into a power outlet. How do I fix it?
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Hi @lwuisc
Suggest you to check on the battery.
Remove and inspect the pins ......
when you power up by power outlook, do you see the battery charging?
por
Adicionar um comentário
