Ir para o conteúdo principal
Second generation of the Ford Focus.
Having trouble with a 2007 Ford Focus, what do I do?
Having trouble with a 2007 Ford Focus, getting spark fuel, everything just will not turn over
bumped the coil will not start.
the alarm light keeps flashing ran a tester wire is enabling through the alarm system everything is working but it will not turn over and start but it turns over when I bump the solenoid with the battery but will not start
what could it be tried the ignition switch key and key reader
I tried the ignition switch relay those were good and checked all fuses everything is all good but I think it has to do with the alarm on the car itself
what do I do?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
I know this may seem like a stupid question, but did you check the starter itself? Also there are usually fuses and relays underneath the hood, did you also check those?
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Harvie Oconnor será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 42
Ao todo: 282
