Ir para o conteúdo principal
The sixth-generation Volkswagen Jetta, known as the NCS (New Compact Sedan) during its development, was announced in the North American market in June 16, 2010.
19 Perguntas Visualizar todos
Mirror problem with light telling someone is passing
The light that tells you someone is passing you is not working?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi @harryii ,
Is the Blind Spot Monitor function light coming on in the dashboard instrument cluster, when you first turn on the ignition key?
Here’s a close up of what it looks like (picture of a car in an exterior car mirror)
If this light is not showing when you first turn on the ignition you need to activate the Blind Spot Monitor system.
(click on images to enlarge for better viewing)
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thank you for your help.
por
Adicionar a sua resposta
Harry Grozio será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 6
Duração total: 394
