Ir para o conteúdo principal
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
778 Perguntas Visualizar todos
YLOD to RLOD after update
After doing a Sony Update, my system rebooted and then flashed the YLOD then went to the RLOD then turned off. I have checked the Hard drive to make sure it was seated and replaced the past on the CPU Sinks. Since Sony wants $150.00 for the repair, I am hoping to do the repair myself. I am a Certified Computer Tech, but have very limited knowledge on these gaming systems. Is there anything I can do to fix this problem?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
There's a very good chance that it is bricked. This means that the software is corrupted, and the system cannot start up. You could try to boot it to the recovery menu, and re-install the firmware. Hold down the power button until it turns on, beeps a few times, and shuts down. Now, hold down the power button again, until it beeps twice, then double-beeps. If successful, you should see a menu on the screen, saying to connect a controller. Select the "Rebuild File System" option, and let it complete the process. If you cannot get to the recovery menu, then there is no way for you to fix the problem, and you will have to send the PS3 to Sony, or replace it.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thanks for the answer, I will try that tonight when I get the chance.
por
Adicionar a sua resposta
Brian Wall será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,919
