Ir para o conteúdo principal
The Samsung Galaxy S Vibrant is an Android mobile device carried by the T-Mobile service provider.
5 Perguntas Visualizar todos
Why won't my Vibrant play any system or media sound?
I recently purchased a Samsung Galaxy S (Vibrant) T-959 off of ebay and it has the most unusual audio problems. It will not play any media sound or system sound through the external speaker. The handsets' built in earpiece will not transmit any sound either. And lastly, the headphone jack will only transmit audio through a single earphone. At first, I figured this would be an easy fix through the cheap and simple replacement of the earpiece speaker/ headphone jack / light sensor assembly that comes all in one piece. This made no difference once installed and the malfunctions continued.
What makes these audio problems even more perplexing is the fact that the external speaker does in fact work. The phone will play ringtones etc, but nothing else. I then took the cellphone to a repair shop where the service people were convinced it had to be a software issue. They upgraded the operating system to Android 2.2, but once again the problems persist. I am now at a complete loss. Any ideas?
P.S.
Yes, I did try adjusting the volume levels under system settings...
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Pergunta mais útil
Maybe it is stuck in "headphone mode" where it thinks there's a audio cable still plugged in. use a head phone cable to push in and pull out rapidly until the problem is fixed.
this is a common problem with my palm pre. works every time after i do this for a while.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thanks for the suggestion, however, I thought that was the case initially and I bought a replacement headphone jack and installed it. The replacement did not solve the problem though. Also, before I replaced it, I did try to push and pull out the head phone cable rapidly many times, as you mentioned, and that still made no difference.
por
I Sorta Have The Same Problem But Instead My Vibrant Was Dead And I Had To Do Everything In Order To Get It Working. My Phone Cant Play NO RINGTONE Though. Please Help!
Pontuação 0
Adicionar a sua resposta
Lech será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 2,536
