iPhone 6s 64GB restarts when plugging charger.
Hello. I own an Iphone 6S and sometimes, when i plug the Lighting port, it restarts. If i immediatly remove the charger, it turns off. This even happens when the cable isn’t plugged in the charger. Battery only 38 cycles, drains fast, but i think is a chinese one, not OEM. What could be the problem of restart and how i can solve it?
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
Visite Nossa Loja
3 Soluções
Solução escolhida
Has anything happened recently to your phone, such as a drop, repair attempt or contact with water?
Otherwise, does the phone work fine?
The things I would try to start are a different and preferably Apple original/MFi certified Lightning cable. If that doesn’t work, then I would try to replace the battery and then finally replace the Lightning Flex.
Esta resposta foi útil?
Pontuação 3
Comentários:
Just replaced the battery. I use original charger that came with the phone in the box. No drop, no water contact. The phone works awesome, very fast.
por
I know you just replaced the battery but you said is was a cheap China battery. The battery is the weakest link in the chain. Try a new battery!
por
Also it has 93% battery life. I will change it with an OEM one. I thinked this might be a short circuit, but it restarts even when the cable is not connected to charger.
por
Firs of all let’s understand how lightning connection works… charger cable has small brains to tell to device that it is ready for charging. When device confirms just then power starts going through connector pins. So if your device keep failing to receive power or keeps restarting that means u have faulty logic board…
Pontuação 0
Comentários:
It’s not keeping restarting, it’s charging normally. It just restarts sometimes when plugging the cable.
por
I think i found the problem. The battery acts very weird. Discharged to 1%, turned off because of battery, after plugging in 40% battery, died in 10 minutes.
Pontuação 0
Adicionar a sua resposta
Răzvan Alexandru será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Todo: 50
