Ir para o conteúdo principal
A personal computer that resides in one location with its core components inside a case separate to third-party peripherals required for operation, such as a mouse, keyboard, and monitor.
542 Perguntas Visualizar todos
Replacing the motherboard's RAM bracket
hi, i have a motherboard that its rams brackets are not exist. how can i myself replace that brackets?
Update (09/12/2018)
i means they are brocken and missed.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Do you mean the motherboard has markings for a ram slot on that area but there isn’t one put on there?
Those require soldering and nobody knows if that ram slot will work on that motherboard because it could be that the circuitry for that ram slot is not implemented.
Esta resposta foi útil?
Pontuação 3
If you really want to replace these missing brackets, I suggest you go on Ebay and purchase an identical motherboard; then install the better motherboard in your computer, and use the other one for spare parts.
Pontuação 1
Adicionar a sua resposta
reza será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 125
