Ir para o conteúdo principal
5-Inch Portable Vehicle GPS with Lifetime Maps and Traffic (Discontinued by Manufacturer).
Why does my device not turn on unless it's plugged in
It’s actually a Garmin nuvi 2995 but that isn’t listed.
It will only turn on when plugged into the car, my PC or a USB charger, then it works OK.
I’ve left it plugged into a USB charger for over an hour, but it still won’t turn on unless it’s plugged in.
Can anyone suggest a fix ?
Esta é uma boa pergunta?
Pontuação 2
4 comentários
are you sure that is the correct model number? I can't find anything about a 2995 model
por
I made 2 mistakes, it's a 2559 and, I thought charging it for an hour would be enough, it wasn't.
Charged it overnight, all ok now. Found out where to buy replacement batteries though.
Thanks for the help.
por
I have the same issue with a brand new Garmin ETREX 22x.
por
I have that problem with my Garmin nuvi55. Bought a new battery & still have the same problem
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Your battery unfortunately has probably gone bad google the model number and see if its repairable lucky in 2018 theres a video for everything. I don’t know if Ifixit will have parts for it try ebay if not look for good vendor.
Esta resposta foi útil?
Pontuação 1
My mistake, I thought charging it for an hour would be enough, it wasn't.
Pontuação 1
Adicionar a sua resposta
Frank Edgar será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 19
Ao todo: 1,966
