Can I change a motherboard to iphoen 7 plus
i have iphone 7 plus that has 4016 error which means base band error so should i install new mother board ?
Esta é uma boa pergunta?
If you have an Error 4013 on an iPhone 7, then you need to determine if it is a Qualcomm or and Intel baseband chipset. The Qualcomm chipset has a high failure rate caused by an internal short within the IC itself. If that is indeed the problem, it is essentially unfixable (Check out the answer here by @jessabethany for more details).
You can replace the logic board but they usually cost as much as a replacement device so consider your options carefully.
Esta resposta foi útil?
Here’s how Apple says to fix it:
To answer the title of the question, yes! It is very possible to do so and I will provide an iFixit guide for you below on how to replace it. Does it need to be replaced, I do not know. I have never heard of such an error and someone more experienced will have to answer that one.
error 4013 my mistake
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 546
