Ir para o conteúdo principal
Um videogame de tv fabricado pela Sony Computer Entertainment, também conhecido como PS4. Primeiramente anunciado em 20 de fevereiro de 2013 e lançado em 15 de novembro de 2013.
1695 Perguntas Visualizar todos
Replaced PS4 Optical Drive still won't work
The CD spins for a few seconds and then it stops. Then I get an unrecognized disc error. I have replaced the ribbon cables that attach to the motherboard and nothing.
Can anyone help me?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Solução escolhida
You need to use the orginal motherboard that was with that replacement drive.
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
sounds like the drive itself is bad
Pontuação 1
2 comentários:
If this is the case the Bluray laser in the drive will need to be replaced.
This is done by keeping the original drive board that came with the console and transferring that to a replacement Bluray drive and use that.
por
agreed. keeping the original board is very important. won't work without it
por
If your drive still doesn’t work after replacing it could be the fuse on motherboard.
Search google & replace the F6202 fuse (check the others near it as they could be a problem also).
This fixed it for us. No new drive or motherboard needed.
Pontuação 0
Adicionar a sua resposta
Kevin Emmanuel será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 195
