Ir para o conteúdo principal
Guias de reparo para telefones móveis Android fabricados pela Motorola (uma subsidiária da Lenovo), incluindo celulares, smartphones e a popular linha de produtos Droid.
2399 Perguntas Visualizar todos
How do you fix the power button on a Motorola Android?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
HI!
It completely depends on the model of phone. I believe that most Motorola smartphones have the power button soldered to the motherboard. You may need to locate a local shop with the ability to microsolder. We offer that service here at BrainWave Cellular and there are a number of other great shops that can help! Can you provide the model number of the device? It should start with XT.
Cheers!
Joshua
Esta resposta foi útil?
Pontuação 0
As stated by Joshua above, the actual switch is a surface mounted switch. There are a few different ones for the Motorola line (3 I have seen so far). Yes this will require someone skilled in micro-soldering. You can check with your local UBreakIFix store about changing out the switch too.
Dan
Pontuação 0
Adicionar a sua resposta
maisiem.moreno02 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 46
