How can I test the power supply?
Will not start up---battery is good--power supply is in 2 sections--
Esta é uma boa pergunta?
If you have a voltmeter or a multimeter you can plug in the power supply into the wall and probe the other end with a voltmeter. This should at least give you an idea of the thing is alive. I have seen many cases where the AC cord is bad and the actual power brick is fine.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,388
2 comentários
Does it do anything? Sounds, lights, smells?
por mayer
I will Check the cord next--unit does not make sounds no smells--like a rock---I have it pulled apart---
por mark
