Sensing Light Flashes, Hear a Click, But then Nothing Happens
I replaced the Lid Switch and verified it is working with my meter. I pressed the start button and the panel gave me the Lid Locked light and it locked the lid, plus started draining water that was still inside. I flip the fill knob so it would fill with water and it did, but it did not start to agitate the clothes.
The next day I press the start button and can hear a click when the dial is set to spin or drain, but the green sensing light just flashes, I can also press start again and the sensing light will go solid, but no other lights and still nothing works. No drain, no fill, no lid lock, nothing but the click. I did verify with my meter that the lid switch is still working.
I am thinking that the control panel might be bad, but the click makes me think it is okay.
PLEASE HELP!!!!!!
MODEL 110.20022013
Esta é uma boa pergunta?
12 comentários
Done Right ASAP what is the complete model number for your washer?
por oldturkey03
model #: 110.20022013 type: 587-07
serial #: c32331732
por Done Right ASAP
The washer says sensing but don't start
por Larry Mcendree
I am also having issue with my maytag top loading centennial washer. I depress start button, green sensor light all the way on left flashes, red lid lock sensor comes on and then nothing happens. any thoughts.
por bldwarren
I tried slamming the lid - didn't work - then got the idea to spray compressed air on the lock- it worked! Must have had some lint blocking it!
por nlance
Exibir mais 7 comentários
