Ir para o conteúdo principal
right trigger button keeps firing when I let it go
when playing a game ie with guns the right trigger button keeps fireing when i let go of switch after that if i tap it some more it will turn off then when i press it again the same thing can this be fixed thanks jacob
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Solução escolhida
try getting some canned air or a soft brush and see if you can remove any dirt/old sweaty skin cells etc that build up around the button which can cause it to jam.
Esta resposta foi útil?
Pontuação 2
The best you could do would be to take it apart and see if you could clean that area. I would recommend a brush or q-tip with rubbing alcohol. In order to open the controller you need a security tox screwdriver, you can get them off of eBay for a decent price.
Pontuação 1
What about replacing the trigger sensor. They sell replacement parts on ebay for that.
Pontuação 0
Adicionar a sua resposta
jacob k será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 20
Duração total: 15,273
