Ir para o conteúdo principal
The Enclave has seating for seven passengers, with an optional second row bench seat instead of the standard two captain chairs which increases the seating to eight. It comes standard with front-wheel drive with an option of all-wheel drive.
6 Perguntas Visualizar todos
Why would my car sometimes not start?
I have a 2010 Buick Enclave - last week at lunch my car wouldn’t start. I got a jump, drove to AutoZone explained what happened, tested the battery, fully charged battery. I had my dad check all of the connectors on the battery - all were good. Today, went to start the car, nothing….. Jumped it, started right up. Read a lot of blogs of people with the same problem, no solution. Any ideas?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
You might want to have the under dash fuse box looked at for water intrusion. This is a common problem with these vehicles, also check the obvious things loos connections at starter and batter. Hope this helps
The fuse box is way behind the glove box very far back hard to see.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Staff.April Moloney será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 10
Duração total: 500
