Ir para o conteúdo principal
The Samsung Galaxy S4 Active is a rugged version of the Galaxy S4. Currently, it is only on AT&T's 4G LTE network.
Stuck in 'download mode' when trying to do a reset
I just got a S4 Active that a former coworker turned in. He claim to have done a ‘factory-reset’ but I am not quite sure to what extent that reset worked since the graphic lock is still active which he apparently never used. And I need to get past that lock.
From what I have gathered a real ‘factory reset’ should take care of this.
So first of all, is that correct?
Now, I can’t do the factory reset itself since I get stuck into download mode. I have followed all solutions I could find and the problem still stands.
The steps that I take are:
1. Turn off phone/pull battery for 30 min
2. Hold volume down + power to enter ‘safe-mode’ or whatever. And I am quite certain the volume down button is not stuck.
3. Get sent straight into download mode after that.
The volume button can’t reasonably be stuck. It makes a clicking noise and I can feel it physically click. It wasn’t stuck pre-’reset’ and when I enter download mode I can click volume down to cancel download.
What do I do here? Are there any other relatively easy steps to get pass the graphics lock?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
To get to factory restore setting you have to use power button + home button + volume up.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
08132029 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Ao todo: 231
