How can I fix it without opening the back?..
My tv is dark all over after i spilt water all over it …..the audio is still working how can I fix it without opening the back?..
Esta é uma boa pergunta?
Teddy Mararo you can’t! You at least will have to remove the back from your TV to evaluate the damage. This could be any board as well as the panel. If you let us know what make and model your TV is we can probably help you further, but you will have to remove the back.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 30
2 comentários
Its an lg flat
por Teddy Mararo
There should be a couple of numbers with it. Check the label on the back Lg......
por oldturkey03
