Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
White vertical lines screen partially unresponsive
The iPhone was dropped and now there are 5 vertical white lines on the right side of the screen. Where the white lines are the screen is unresponsive. However, when I diconnect and reconnect the screen I can sometimes manage to get the lines to switch to the left side and then that side becomes unresponsive.
Any ideas other than replacing the screen and digitizer?
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
Kits para Nintendo Switch
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
1 Resposta
Pergunta Mais Útil
This is a connection issue. Often when connecters are not seated properly (especially on the 5 series and SE) the screen displays bars.
Id suggest removing the display, checking the connectors arnt damaged, clean the connectors with isopropyl and see how it goes from there. Also, make sure the cables are not getting twisted or stretched when laying the screen back down.
Esta resposta foi útil?
Pontuação 1
Comentários:
Sounds like the screen needs to be replaced either way if it happens after a drop.
por
Adicionar a sua resposta
Kyle Benning será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 174
