Ir para o conteúdo principal
Encontre soluções para as questões de reparo do seu computador.
21255 Perguntas Visualizar todos
Disk usage 100%, nothing running
So task manager shows my disk usage is 100%. I am currently not doing intensive pc work. What is causing this problem and how can I fix this? Screenshot included
Esta é uma boa pergunta?
Pontuação 0
1 comentário
I have a Alienware x51 R2
por
Adicionar um comentário
4 respostas
Solução escolhida
Had this problem on a number of computers running Windows 10.
Current (March 2019) Windows 10 Updates fixes most of this high drive activity.
Spy-Bot’s Anti-Beacon software will block most of MicroSoft’s snoopy telemetry software which also causes much drive activity.
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
This is very common in windows 10. I wasn’t happy when mine was doing this so i installed an SSD. Problem solved
Pontuação 1
1 comentário:
Everything worked well before, a couple of months now my pc is getting slower.
por
The computer is busy because Windows 10 is doing one of its many updates. Currently (2018) the only easy workaround is : let it run some hours while you are away…
For more help, you may read “Why are Windows 10 updates so slow? “ (may 2018) : https://www.techadvisory.org/2018/03/why...
Pontuação 0
How to protect computer from cryptojacking
https://techfordaily.com/how-to-protect-...
Pontuação 0
Adicionar a sua resposta
Ruben Debbaudt será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 6
Duração total: 569
