Ir para o conteúdo principal
What should I do if the Apple 6 capacitor screen is broken?
Esta é uma boa pergunta?
Pontuação 0
4 comentários
What do you mean by "capacitor screen" ?
por
I believe the OP means "capacitive touch".
por
yes,it is capacitor touch screen
por
@refectio I've not heard that distinction for quite some time now ;)
por
Adicionar um comentário
1 resposta
Solução escolhida
As @arbaman suggests, it would help if you explained what you meant by capacitor screen. A capacitor is a discreet component that is used within the logic board and is generally not associated with the screen itself. However, the digitizer is based on a capacitive touch interface so I’ll assume that is what you meant.
If the screen is defective, then it needs to be replaced. It is a fairly straightforward repair so you can do it yourself by buying the appropriate parts (the kit has all the necessary tools) and checking this repair guide.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Annaa será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 270
