Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
2050 Perguntas Visualizar todos
Chances of getting repair or replacement
my iphone 7 which is on 11.4.1 has the greyed out speaker. It has 71 days left on the warranty, and i have an appointment with a certified apple repairer. I am going to try and get repair or replacement . I am in the UK
What are my chances? if they refuse, can i appeal?
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
I agree with Tom, there is no reason they should refuse your warranty unless there is external or internal evidence of damage or prior “unauthorized” repair. If you do get an unhelpful Genius, you can ask for a manager or try again another day or at another store.
In a worst case scenario, the AudioIC problem is well documented and a long-term solution is at hand via repair shops that do micro-soldering repairs.
Esta resposta foi útil?
Pontuação 2
Comentários:
My appointment is tomorrow. I will post a update here with the outcome. I also see no reason why it should not get sorted, but i am worried as i cannot afford to replace it if refused. obviously it has signs of use, but no major dints to the case, everything else still works, even the fingerprint ID.
por
Good luck! Let us know how it works out.
por
Why would they refuse warranty?
Pontuação 0
Comentários:
I have been reading up and some people have been refused. Are apple refusing to acknowledge it is the update that caused this?
por
If there is an issue, it is in warranty, there is no sign of excessive abuse, why would they reject a perfectly good warranty claim?
por
Adicionar a sua resposta
sam caspian será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 59
