iPhone 6 not showing any current, only show voltage
Hi I got an IPhone 6 sent in to me for repair regarding charging issue. This phone has no water damaged history. When charging the ammeter showing 0.01 - 0.02 (current), then I probe the battery connector while charging, my multimeter showing normal voltage (3.5v - 4.2v)
Okay let me straight forward, I’ve changed Charging Port, Battery, Tristar, Tigris and also i already checked the FL2511 it showing good sign. PP_5v0_USB also normal. PP_Tristar_Pin shows normal too
So what should I do next ?
Esta é uma boa pergunta?
1 comentário
did you check for vcc_main short
por daniel
