Ir para o conteúdo principal
Boots up when insert battery, can’t shut off
I am trying to replace a battery in a MacBook Air and as soon as I put the new battery in, the device boots up. If I then turn it off, it boots up again within a few seconds. It seems impossible to turn it off so it stays off. Does this mean there has been a short somewhere? There was no water damage that I know of (not my machine).
Thanks!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Reset SMC by Pressing shift + control + esc and use power button to boot into recovery mode in that there is an option to reset SMC
Esta resposta foi útil?
Pontuação 0
1 comentário:
Thank you for the reply!
Actually right after this comment I tried putting the new battery in again, and when it booted up I held the power button down to turn it off. Now, instead of starting up again right away by itself like it used to, it won´t turn on at all, even when plugged in with power cable. So not sure what´s going on there. Would this be a logic board issue?
por
Adicionar a sua resposta
Vera será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 23
