Ir para o conteúdo principal
Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
Apple home button won't stick bag
Changed the screen on my iPad, however, when i reconnected the home button on the new screen and stick the back plate holding it, its not staying the home button keeps sinking back inside the iPad. Any ideas of what I can use to keep it stuck?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
You need to replace the old adhesive on the black home button bracket. Either Tess 61395 or 4695 will do the job.
61395 is thin and strong which is ideal but 4695 can do the job too but doesn't give the best finish.
Esta resposta foi útil?
Pontuação 2
Just for clarification.
I think Ben meant Tesa 61395  or Tesa 4695 double-sided mounting tape.
Pontuação 1
Adicionar a sua resposta
MICHAEL JABARI NELSON será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 7
Ao todo: 250
