Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
2264 Perguntas Visualizar todos
iPhone won't charge but logic board gets warm
Okay so I was recently changing an iPhone 7 screen and I unplugged the battery from the logic board. I know it’s stupid but I didn’t realise the screen was still turned on. Now when I charge the device it no longer turns on or shows any response. However, after a while the logic board gets warm. I’m not an expert so I need a little help. It’s definitely not the screen because it was working before. The backlight is fine and the charger is working. Any ideas as to what the problem might be?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Did you try a soft reset? Just asking,trying to see what troubleshooting you did.
Esta resposta foi útil?
Pontuação 1
3 comentários:
I held down the power and volume down buttons for a while. Didn't work. The battery had issues before I even worked on the phone as well, it hadn't been turned on since December.
por
Did you try unplugging the battery and plugging it back in because it sounds like you did the screen replacement with the battery plugged in the whole time.
For doing any screen repair it's good practice to unplug the battery first if possible or soon as possible.
por
It's quite confusing but I actually successfully completed the screen replacement to test the actual screen. Then I did it all again to fit in the home button, that time it wouldn't charge again.
por
How do you know all these things are working if you are getting no response from the phone? do you have a power monitor you can hook it up to and see if you are pulling anything at all??
Pontuação 0
2 comentários:
I don't have a power monitor, but I know these things are working because they worked literally seconds before. I checked the backlight with a flashlight and the charger works with my other phones. I tried the old screen (which was cracked but working) and still no response.
por
Do you have a multimeter to test circuitry? You may have shorted something when you disconnected the battery. There is definitely some testing that will need to be done before you can find a solution or verify parts work.
por
Adicionar a sua resposta
Tahiyan Choudhury será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 63
