Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Phone crashed while testing new screen (no screws installed) iTunes ok
I was replacing a screen assembly on iphone 6. before putting the screws back in I turned the device on and tested it. it was working fine. The digitizer shifted a tiny bit (maybe it pulled a connector off?) but the phone went off entirely. I have not been able to get it back on since. I did try a second brand new replacement screen assembly (known good) and it does the same thing.
I can power on the phone and iTunes DOES see and communicate with it.
I installed the screen again (no home button or any connectors except the screen and digitizer) - powered on, used a flashlight and could NOT see anything on the screen in the dark.
All pins on connectors look good. I dont thinks the backlight filter since I cant see anything with a flashlight.
Any ideas or suggestions. Thanks
Esta pergunta é pertinente?
Pontuação 0
Comentários:
I should mention, I did not put any screws in so it did not short anything out that way.
por
Adicionar um comentário
1 Resposta
Pergunta Mais Útil
First thing would be to take a close look at the connectors and surrounding areas for any physical damage. If you cannot see anything at all even with a clean screen and a flashlight, you may be looking at a display IC. If just the backlight goes out you can still see a faint image, but if just the display driver (u1501) or display boost (u5302_RF) goes out you can usually still see a backlight on with the screen outside of the frame. Hope this helps, but always start with the easy stuff, like looking over the board for physical marks.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Kyle B será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 35
