Ir para o conteúdo principal
Seagate Wireless Plus Model: 1AYBA4 Storage: 2Tb https://www.seagate.com/manuals/network-storage/wireless-plus/
Battery replacement for Seagate Wireless Plus 2Tb?
Battery has been deteriorated since 2014.
I did teared down the devise. ordered battery on Amazone, but it does not fit model 1AYBA4.
Made lots of search, looks like Samsung Mega 6.3 i9200 battery should fit.
Kindly advise if anybody got fixed this issue.
Thank you in advance/
Esta é uma boa pergunta?
Pontuação 5
4 comentários
What is the make and model number on the old battery?
por
Rechargeable Li-ion Battery
Model Name: P11PG7-02-N01-1AYBA4
Rating: 3.8V 3150mAh 11.97Whr
Assembled in China
Manufactured by SAMSUNG
por
кто знает аналог? чем заменяется?
por
The original battery in the 2Tb Wireless pluss is a Samsung p11pg7-02-n01-1ayba4, 3.8V 3150mAh battery with three contacts on the end. All the options when you search for this have a three wire cable. They work but you have to solder the wires into the circuit board - not a trivial task but it does work.
por
Adicionar um comentário
3 respostas
Pergunta mais útil
Hello
Having searched the web for the P11PG7-02-NO1AYBA4 battery over many many months I eventually gave up my search. Then I came across a listing that claimed to be a replacement for the aforementioned battery. https://www.amazon.co.uk/3200mAh-Battery... . I was sceptical at first and then I thought why not try it, especially as the battery was keenly priced at £5.85. After a very short delivery time with amazon and disassembling the drive, which any DIYer could do, and inserting the new battery, hey presto, the drive works perfectly. The replacement battery is a 3200mAh 3.8V Battery for Samsung Galaxy Mega 6.3 i9200 i9205 i9208 (B700BC). I hope this helps.
Esta resposta foi útil?
Pontuação 2
4 comentários:
And what is even better, no fiddling with wires and a soldering iron
por
I ordered the battery from Amazon in the US and it has worked great, a very easy replacement, it just drops into the Seagate Wireless Plus once you get the back cover open. No soldering or glue at all - thank you so much for documenting this!
por
That's fantastic - ordering today!!
por
I ordered one from eBay and it works perfect it is a straight replacement some people have suggested they are glued together on mine on the back there are 4 small rubber plugs if you pick them out, you will find 3 screws once you undo those it will come apart easy https://www.ebay.com.au/itm/131841018430...
por
I ordered a battery that claimed to be for the 1AYBA4. It was not. I eventually order this battery and it worked perfectly .https://www.amazon.com/gp/product/B00EL3...
Pontuação 0
Does the Seagate wireless work with the battery removed & using an external power source? My battery has expanded & I wonder if I can just use it with an external battery pack instead of soldering in a new battery.
Pontuação 0
3 comentários:
I have a similar issue, waiting for my toolkit to arrive to give it a go.
If you will figure that out, make sure to follow up here :)
por
I have disassembled mine, and I can confirm that it does NOT work only via a usb cable. PCB shuts down a few seconds after plugging device into the port.
However the drive which powers device is regular SATA HDD, so it's possible just to plug it into another batery-less enclosure or PC motherboard
por
I think that there might be an issue with the charging circuit - the Seagate Wireless Plus manual say that you should not leave the drive connected to the charger, only connect it to charge the battery up. and then disconnect it. This means that you have a good battery life but leaving it charging will kill the battery after a year.
por
Adicionar a sua resposta
Dmytro Cherkesov será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 20
Ao todo: 3,899
