Repair guides and support for your Samsung TV.
1341 Perguntas Ver todas
No Power, No Stndby light, when the main brd is unplugged back light
Okay so I have a Samsung 55 in model number un55ES7100XZA . The television set was power cycling every couple of minutes now there is no standby and no power to the TV after replacing the power supply still no changes but when I remove the cable from the power supply to the mainboard my back lights come on. I don't want to continue to throw Parts at it because the main board is extremely hard to find is this a common issue for these TVs
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
Visite Nossa Loja
3 Soluções
Solução escolhida
It is unusual for a standby light to be affected by a problem within the set that is not related to the power board. Since removal of the connector to the main board allows the back light to work, suggests that the problem is related to the main board. This is not a common error as far as I know. Was this set involved in a power surge or power outage recently?
There is a repair service for the main board that may work for you. See the link below:
https://www.ebay.com/itm/Repair-Service-...
Dan
Esta resposta foi útil?
Pontuação 1
Comentários:
Thanks Dan I believe you are right . I found a replacement board that may work . I've been in contact with that shop on ebay that you mentioned about a flex cable issue and I've desided to send them all my board work from her on out. Thanks and I'll let ya know how it goes.
por
Resposta Mais Útil
@roddykelly “there is no standby “ and if you do not have any standby voltage on your main board, it is the main board that has failed. That is most likely the reason why the main boards are not readily available.
Pontuação 2
Comentários:
Thank you, I've just started tinkering with tvs and every one is a new animal, I appreciate that folks can take the time to answer questions and lend a hand. Yall rock
por
You probaly ether blew a fuse or pugged it in backwords therefor frying the prosseser
Pontuação 0
Adicionar a sua resposta
Roddy Kelley será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 44
