Ir para o conteúdo principal
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
769 Perguntas Visualizar todos
I keep getting signed out of the playstation network
Everytime I try to connect it keeps saying you have just been signed out of playstation network. I have re-tested the wireless Internet connection and everything works fine except for not letting me sign in to the playstation network. Can you please help?
Esta é uma boa pergunta?
Pontuação 6
9 comentários
I AM GETTING THIS ( error code 8002A537 ) EVERY TIME I LOG IN TO PS3 AND my ps3 keeps freezing up and all so i keep losing my sound of game play but not the mic sound ?
por
@craig371 same $@$* here!
por
My ps4 every time i turn it off it makes me log back into my account when I turn it on and when I go on my games it makes me do all the beginning stuff again.
por
My ps3 says an error has occurred. Signed out of playstation network (error 80710016) or something like that then I go to test wifi and it doesn't even show anything but connection to internet and it address found it doesn't say psn found and all the other stuff please help I just bought a shark card in gta5 for 50 bucks
por
Have you found a solution to your problem??I have the same too!!
por
Exibir mais 4 comentários
Adicionar um comentário
4 respostas
Solução escolhida
Martin,Is this a new error? did you change any of the setttings? Has anything preceded this problem? You can give this a try. In the settings under network, disable Media Server and disable Auto Sign-in as well and see if that makes a difference. If that does not work at all for you, it could be that the IP address on your PS3 is wrong. That way your PS3 cannot connect via router to the internet, no matter what DNS you have configured. Set your PS3 to obtain the IP address and DNS server addresses automatically via DHCP from the router. You do not need to configure the OpenDNS servers explicitly on any connected devices, whether it be a computer, or PS3, or Wii, or iPhone, etc. I believe that there might also be issues that originate from the wireless controller, but I have not researched that possibility in depth.
There is plenty of info about this happening and I am sure it is not a hardware issue but a software setup problem. Check here and here as well Good Luck and I hope this works for you.
Esta resposta foi útil?
Pontuação 5
3 comentários:
Could someone translate this into English? We don't all know what DHCP and DNS/OpenDNS means.
por
disable the upnp in custom network settings!
por
@unicron75 you don't need to know what thay are. just go through the manual internet settings and set everything to automatic. that should fix your PlayStation's internet connection problem's. i hope that helps you to get your PlayStation back online.
por
mine wasn't an internet problem, just one of my accounts on my ps3 won't sign me in. I did some reading on forums and it MAY be some kind of hack that little baby modders figured out to ban someone from psn for a day or two. I was kicking but with a rocket launcher on Advanced Warfare and one of them could have kicked me out. Did your game play !#^& off a modder? that might be what happened...
Pontuação 1
4 comentários:
Is this happening to all ps3's?
por
I also have same problem with my ps3 always say PSN signed out any idea what can it be done
por
yup lil dweebs with some new hack.. mine just got killed tonight.. maybe try signing in on another ps3 console
or just play my ps4 might be less cheating dweebs in there
por
my psn has been issues code
por
I dont have an answer its just a similar thing happening to me because i go on to minecraft ps3 and i try to go online but it says “you have been signed out from the psn. Online features of the game will not be available until you sign into the psn. Exiting to main menu” i am on psn but i have logged out and gone back in many times and i have tried to search up what is happening but it has not helped what so ever. Is it something to do with maintenance because it said it was but it also said that it’d take two hours but its been about 15 hours. Anyone know what is going on?
Pontuação 1
4 comentários:
And yes i do still have Ps3 in 2021 ??
por
My son is having the same problem today on our ps3
por
we are having the same problem in ours
por
i know why the online modes for minecraft on ps3 aren't working. thay were discontinued when microsoft released the bedrock edition to the ps4. even if sony supported the ps3 minecraft online modes it was only for 6 months a year or so. sorry to be a pain in your side. but it might be time to get a used ps4 slim or a ps4 pro, or if you can find one get a disk based ps5. then you can minecraft online all you like. i hope this has helped you all.
por
to everyone here. if your PlayStation is having trouble connecting to the internet, or to psn, try updateing your PlayStation system software to the latest version, that might be all you need to do to fix the problem.
Pontuação 0
Adicionar a sua resposta
Martin será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 54
Últimos 30 dias: 166
Duração total: 82,485
