Ir para o conteúdo principal
The 2008-2012 Ford Escape features a revised front and rear fascia and restyled LED tail lamps.
50 Perguntas Visualizar todos
Why is my ac not working?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Sounds like your AC compressor could have gone out, does your vehicle still run heat? If so it is your compressor, usually these repairs run from around $200-$300 depending on the shop's labor charge. If your heat does not work, it could be the blower.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Often times you get a refrigerant leak in either the hose or pipes which needs to be fixed before recharging the system. You don't want to run the AC without the refrigerant as you can damage it.
por
Adicionar a sua resposta
Lorraine Weiser será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 17
Duração total: 1,487
