My charging port is messed up
hi my charging port is messed up, keeps going On and OFF and in the middle of the route.What can I do to fix loose port?
Esta é uma boa pergunta?
use this guide Garmin Nuvi 1390LMT Logic Board Replacement to get to the port. It is soldered to the mainboard. You could check and see if a resolder might fix it (if one or two of the contacts are loose). Worst case would be to replace the port. Hardest part on that would be to source a replacement. Once you have the board removed, post some images of your port etc. with your question. That way we can see what you see. Use thius guide Adicionar imagens a uma pergunta já existente for that. We might find other solutions based on what we see.
Guia
Nível de dificuldade:
Muito fácil
2 - 5 minutes
Guia
Moderada
15 - 35 minutes
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 144
