Does not turn on unless plugged in
Can not turn on phone unless it is plugged in wall
Esta é uma boa pergunta?
It has to be some problem with the battery. is it holding charge while is plugged in the wall?
Esta resposta foi útil?
Yes it is holding the charge. But will not turn on unless it is plugged in outlet
I would recommend you to get a new battery,Unless you phone has water damage. If that is the case it might be some issue with the logic board.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 29
