Ir para o conteúdo principal
Câmera DSLR da série 500 desenvolvida pela Nikon. Lançada em fevereiro de 2011.
doesn't fully shut off (coolpix b500)
hi,
so my Coolpix b500 (they didn't have that in option) isn't shutting off properly, when i shut it off the green light still is on and the battery's die soo fast! (I use lithium) I have check every setting and have looked on the internet but I cant figure out how to fix it!
please help!!
Esta é uma boa pergunta?
Pontuação 3
1 comentário
Where is the solution to this problem?
por Compartilhar
Adicionar um comentário
1 resposta
Solução escolhida
I have this issue too. What I do is turn it off, put the lens cap on then turn it on. A message will come on the screen to turn it off then on again. Once I turn it off this time the light goes out. Hope this helps
Esta resposta foi útil?
Pontuação 2
4 comentários:
I have done this before but wasn't sure if it was okay for camera and if it fully shut off, thanks!
por Compartilhar
Thanks Karen. I was having the same problem but your solution fixed it. Thanks again.
por Compartilhar
Well done…troubled me for ages…works! Thank you..
por Compartilhar
This method seems stupid to me. To use an error action to make the light go out. What does Nikon say to do to get the green light to go out when you shut the camera off. That should do it on the B500.
por Compartilhar
Adicionar a sua resposta
heusscarolyn será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Ao todo: 2,046
