White LCD and can't sync with Itunes?
I drop my phone like most people do occasionally.
Unfortunately the last fall resulted in a flickering white screen at first and now a solid white screen with the occasional green or grey line when interrupted.
I've gone about searching for repair shops (will be checking one tomorrow) and was advised by the first to sync all my media files to Itunes for storage.
However, when I try to sync the phone with my cpu, I get a message saying that it can't sync the device because the device is powered down.
I'm probably not meant to understand all of this and the reasons why but if the device is on and functions in every other way possible with the exception of the LCD, shouldn't my iphone be able to sync? Does this have anything to do with the motherboard? Is this easy to repair or is my wallet doomed?
Esta é uma boa pergunta?
1 comentário
Thanks for your help guys
Sorry I was unnable to reply much earlier. I had a chores list of events to take care of since my iphone broke.
Never the less, I did have it repaired at a cost that was remarkably not too steep. I also decided to do some research and venturing into my computer.
Apple actually has the answer to the syncing problem. In your control panel is a "switch" that controls your phone's ability to sync with itunes. If you go to the apple website's help section, you'll find full instructions on how to access the settings in your control panel to turn it back on.
por CCMartin
