Ir para o conteúdo principal
car starts off slow and good after. code P0962 . replace how?
I have a 2003 honda accord coupe, no leaks in the transmission at all. When I start to drive the car it takes a lot to get going but after if moves just fine. No problem in shifting and the reverse is good too. Is it the pressure control solenoid valve?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
Dexter Murphy, error code P0962=Pressure Control Solenoid A Control Circuit Low. Had the same happening on my jeep and required me to replace the Solenoid. There is a great flow chart fault finder on here I know it does say civic but the error is the same :-)I also attached an image for the transmission and the solenoid is shown as #4 and sits on the outside of your transmission. Good Luck and I hope you get it done.
Esta resposta foi útil?
Pontuação 2
2 comentários:
Thanks oldturkey03 for all your help. I get the part in tomorrow. I pray this is it. Have a great day
por
thank you for accepting my answer and I hope that you get your error code resolved with the new part. BTW my jeep had the same error code and would not shift gears and drove horrible, after changing a $40 solenoid inside the tranny, drives like new. So we'll keep our fingers crossed...Good Luck
por
Adicionar a sua resposta
Dexter Murphy será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 22
Duração total: 8,954
