Ir para o conteúdo principal
The Chevrolet Corvette, known colloquially as the Vette, is a sports car manufactured by Chevrolet. The car has been produced through seven generations.
'90 Vette conv. doesn't stay on?
This is 1990 Corvette convertible with a manual 6speed transmission. It starts but won't stay on. Now the last owner changed/ replaced a lot of things dealing with the fuel. He thinks 2 of the fuel injectors might be the problem. I am the new owner, first Corvette, and don't know nothing about fuel injection, but first thing I'm thinking is if might be efi(electronic fuel injection), computer/ fuse and or ignition switch. Yeah that reminds me owner did mention something about getting it a new switch. I checked it and it looks like halfway out the steering column...
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
As a owner of three older vette's go to the vette forum
Esta resposta foi útil?
Pontuação 1
If the engine dies immediatly after it starts - look for an air leak after the mass airflow sensor. Rubber boot… maybe underneath.
To double check, unplug the sensor (the computer will bypass and go into speed density - won’t run as smooth but it will run).
Pontuação 0
Adicionar a sua resposta
Mr.Lester H. Pineda será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 136
