Ir para o conteúdo principal
Paired telescopes that allow a user to see really far!
5 Perguntas Visualizar todos
The object viewed is doubled
when i look through my Bausch & Lomb binoculars the viewed object does not appear as a single object but doubled. Or in other words the two lenses are not lining up so when you look at the single object you are viewing you see double vision instead where the object overlaps. Can this be repaired. This set of binoculars is almost brand new and I suspect they were maybe dropped which knocked the viewing alignment out. thank you for your help.
Esta é uma boa pergunta?
Pontuação 1
1 comentário
And where do you buy such binoculars?
por
Adicionar um comentário
4 respostas
Pergunta mais útil
Hi @conch70 ,
As they are “almost brand new” I suggest that you consult the warranty statement that is usually found in the User Manual that should have come with the binoculars, as to what you have to do to make a claim for a manufacturer’s warranty repair or replacement.
According to this User Manual, in the USA and Canada, there is a ''lifetime limited warranty'' on the product by the manufacturer, subject to conditions obviously. Hopefully it is the same where you are.
Esta resposta foi útil?
Pontuação 2
The problem is that binoculars are not in collimation. This might have happened if they got dropped or knocked, but may also have been this way when bought. did you check them? Outside, In daylight?
re-collimating is not for the faint of heart, and no conditional alignment is not the same thing.
If new take them back under warranty, good luck if you dropped them
Pontuação 0
Being a fanatic outdoor lover, I have used numerous types of binoculars. You must maintain your binocular for better durability and service. Before buying the binocular I read this awesome guide on binoculars under 200 I've tried to find out what might cause this, but a google search only takes me to the condition of having double vision, which I don't. I only experience this while looking through our binoculars.
Pontuação 0
What causes it, is that one of two events have occurred.
1.The prisms have shifted in the mountings
or
2.one or other of the doublets have been rotated out of optical alignment.
The main reason for this is that they have received a severe knock at some stage.
It is possible that they came from the factory like this, which is a different issue.
Pontuação 0
Adicionar a sua resposta
michael ferguson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 396
