Ir para o conteúdo principal
Modelo A1502 / processador 2,4, 2,6 ou 2,8 GHz de dois núcleos / Lançado em outubro de 2013
552 Perguntas Visualizar todos
rMacBook Pro 13, late 2013 slow after battery went to "replace now"
Hello,
I am using late 2013 Macbook Pro Retina 13, 2.6 GHz, i5, 8gb ddr, Intel Iris 1536mb, 512 SSD, running on macOS High Sierra 10.13.6 (the latest).
The cycles of my battery are 980. And up until now the battery condition was "service battery". It lasted for couple of hours without being plugged in. But yesterday the condition went to "replace now". After that my laptop became unbearably slow. Apps load slowly, when writing text appears after couple of seconds, tabs in safary take a lot time to load. Booting takes a lot time too.
I don't mind using my laptop only plugged in for now. I've read that "replace now" battery condition could slow down the laptop. Is there a way to dismiss this with software, so that it's fast again? I have tried SMC reset (although I am not sure it worked, because the lamp of the charger didn't change.)
I am unable to change my battery now, because I need my laptop for work. Any suggestions?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Sorry your MacBook is suffering!
You need to replace the battery there is no way around this via software. Order the IFIXIT kit here: MacBook Pro 13" Retina (Late 2013-Mid 2014) Battery and follow this guide: Substituição da bateria do MacBook Pro 13" com tela Retina Final 2013 at most your down for a few hours. If you don’t have the skills to do this then its best to get to an Apple Store or authorized Apple service shop. Thy may take a few days.
Imagem de MacBook Pro 13" Retina (Late 2013-Mid 2014) Battery
Produto
$99.99
Esta resposta foi útil?
Pontuação 1
2 comentários:
Thanks, should I do something before following the guide?
por
Get a good nights sleep, take your time and remember to breathe ;-}
por
Adicionar a sua resposta
Kristian será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 430
