Ir para o conteúdo principal
Announced in March 2015, and released April 10, 2015, the Galaxy S6 is the next flagship in the Galaxy line. The curved screen version is known as the Galaxy S6 Edge.
487 Perguntas Visualizar todos
Fast charger charges other devices, but not one particular phone.
I have a customer who has a Galaxy S6 with a fast charger. The fast charger charges other Samsung devices quickly, even with the same cable. Has anyone seen this be a charge port issue before? I have only seen this as a cable or charger adapter.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
This charging problem is fairly common I think. It is to do with a faulty charging port. You will have to get the charging port replaced and it will work fine. I used to have this problem I temporarily fixed it by putting a toothpick in the charging port and prying the thing inside th charging port up a little but I definitely wouldn’t recommend this. Better safe to just get a charging port replacement
Esta resposta foi útil?
Pontuação 2
2 comentários:
Yeah sounds like charging port needs to be replaced. OP should make sure it gets done via soldering replacement and not the daughterboard replacement as that is high risk in damaging the screen.
por
As my bio states, I've been in the business for over 2 years, and my company seems to have good luck with pulling the screen for the ports. Thank you both for your help.
por
Adicionar a sua resposta
Charlie B será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 51
