Ir para o conteúdo principal
The Mercedes-Benz W126 is a series of S-Class automobiles manufactured by Mercedes-Benz between 1979 and 1992. Premiering in September 1979 as the successor to the W116 line, the W126 was the second generation to officially bear that prestigious designation, an abbreviation for the German Sonderklasse or "special class." The W126 was initially offered with straight-six, V8, and a turbocharged diesel engine for the sedan. A C126 2-door coupé versions was introduced in September 1981.
How can I remove fuel tank?
how can i remove fuel tank?
Esta é uma boa pergunta?
Pontuação 0
2 comentários
My advice is to take it to a repair shop if operable and let them tell you. They shouldn't charge you.
por
@hussein78 what exact year and model is your Mercedes?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
@hussein78 here is the fuel tank removal part from the manual W126-fuel-tank-removal.pdf or you can check on here
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
hussein ahmuda será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 13
Ao todo: 1,940
