Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Why my phone isn't charging?
my phone charging port is broken every time i charge my phone it lights up but its not charging and i need to know if it can but replaced.
Respondido! View the answer Também tenho esse problema
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
OPEN ALL THE TABS
RAM Upgrade Kits for Mac
Confira os kits
Enough RAM
For All The Tabs
Confira os kits
1 Resposta
Solução escolhida
Please be advised that you will need to remove the screen to do this . Take your time aplply heat to the screen with a hot air gun to loosen the glue holding it shut. You will also have to solder the new port to the board . This video shows the whole process https://www.youtube.com/watch?v=76QIweFh...
This person used kapton tape to isolate the area around the port so he could desolder using a heat gun . this was not really show well in the video . Kapton tape disperses heat so only the area you want heated gets heated. Hope this helps
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
diamond batts será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 199
