Ir para o conteúdo principal
A Sony camera in the HX series of the Cyber-shot line.
5 Perguntas Visualizar todos
Can I change the language of my camera from Japanese to English?
Its basically that. I have this Sony Cyber-Shot from Japan. The whole system is in Japanese. I cant understand anything. Can I 'translate' it? By firmware or any way? How? Thanks in advanced!
Esta é uma boa pergunta?
Pontuação 13
8 comentários
hi, i have the Sony DSC-R1 in Japanese version did anyone succeeded to change it to English ?
I HAVE ALSO TRIED TO CHANGE MY SONY NEX C3 & IT DIDN'T WORK :(
por
Any one knows if it's possible for SONY A7 III??
I can't find any answers.... If you know something, please help me! :(
por
Need help to change RX10 M4 menu from Japaness only to English! Thank you in advance!
por
I succeed to unlock all language on my Sony HX60v, with this program: pmca-gui v.17, yuppyyyyy :)
por
File wouldn't open on my Win 10 pc. After may tries the win gui file opened but when I clicked on the tweaks tab it could not find my Sony camera. I connected and reconnected the camera several times.
por
Exibir mais 3 comentários
Adicionar um comentário
12 respostas
Solução escolhida
https://github.com/ma1co/Sony-PMCA-RE/re...
Install GUI version. After installed and camera is connected to USB go to tweaks and you can allow all languages on Japanese version Cameras.
Esta resposta foi útil?
Pontuação 16
40 comentários:
This is EXACTLY to correct answer! Thank you very much for taking the time to reply to this and post this answer.
My wife bought this $750 camera in Tokyo and assumed we would be able to switch it to English when she got home. I could not find the English language setting in the menu. She did a search of Japanese websites and they all stated this was a Japanese only version of this camera; it was not the international version. She was very sad to read this.
This application worked perfectly! First click the tweak tab, second, click the Disable Protection check box at the bottom, third click Enable All Languages check box. Done.
Changing to other languages is now enabled in the camera menu. In the camera you still need to be able to read enough Japanese to find the change language to English setting.
por
Very useful, used on my Sony WX350, japanese language only. Small comment: charge the battery first :-). In order to enable all languages, first has to be enabled 5th box (software unlock, I think).
por
The answer posted by Badger on 27 July is exactly the correct answer.
por
This works with dsc-rx100 model?
por
@joao_vitorio i just tried on my dsc-rx100 model, and it works!
por
Exibir mais 35 comentários
Here’s how:
Language Setting
Selects the language to be used in the menu items, warnings and messages.
  1. MENU   (Settings)   (Main Settings)  [Language Setting]  desired mode
  2. http://docs.esupport.sony.com/dvimag/DSC...
  3. UPDATE 6/29//18
The above failing, talk to Sony directly here on chat:
https://esupport.sony.com/US/p/support-c...
Pontuação 5
3 comentários:
Almost! I can go until 'Main Settings' by following the little pictures icons. From there, I have no idea, since everything is in Japanese writing (kanji). Can you be a little bit more specific? Thank you so much!
por
I discovered with a friend that the only avaliable language is Japanese. Can I change the Firmware? The OS?
por
Does it work with Sony DSC WX500?
por
Here's the user manual:
https://www.google.com/url?sa=t&rct=j&q=...
From that you should be able to work out how to navigate blind to the language setting.
Pontuação 2
1 comentário:
por
https://youtu.be/F_BKXYfPgB8 how to force change language to English solution
just now by majid
Pontuação 0
1 comentário:
por
Persistent rumor has it that cameras intended for the domestic market won't have English as an option.
Did you buy this camera in Japan, or online from Japan? If you did, unfortunately there’s no good chance of changing the settings to English. I doubt they would have different settings for the same company though.
Anyway, you can just check out the Sony community for some possible solutions.
We would all love to hear what you know about this. Please report back.
Pontuação 0
2 comentários:
I wanted to buy the ZV-E10 but unfortunately I became aware at the shop that you cant change the language could someone know if running this firmware it could be possible to do so?
Also ive heard that this firmware does not work with all sony cameras
if so someone can recommend me some like this model?
por
I have the same problem
por
Can we change Japanese language in sony fdr ax700 camcorder? Help me on this.
Pontuação 0
Can you help to make it working for sony A6100 too?
many thanks
Pontuação 0
1 comentário:
I went to Best Buy and the guy there said it is locked in Japanese. I think he doesn’t know what he is doing. Can someone help me!
por
Didn't work for sony rx100vii. You can help-me ?
Pontuação 0
anyone know how can you change the language from japanese to english on a SONY HDR-CX720V. there is another firmware available?
Pontuação 0
Can you help me with my Sony ZVE-10?
Pontuação 0
Hello, With a Sony ILCE-7RM3, bought in Japan, (in Japanese language), is it possible to change the language to French or other, please?
Pontuação 0
Has anybody ever changed the language in a Sony Camcorder? I am looking for a way to change the language in a japanese Sony HDR-GW88 camcorder. Is there any Solution? I started the PCMA-GUI and the camera is regognized but there is no way further option available.
Pontuação 0
Adicionar a sua resposta
guilherme.sarmento será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 45
Últimos 7 dias: 313
Últimos 30 dias: 1,396
Duração total: 40,869
