Ir para o conteúdo principal
Reparo e resolução de problemas do tablet de 7" da RCA lançado em 2014, identificado pelo número de modelo RCT6773W22.
I forgot my screen lock pattern and would like to know how to reset it
I replaced the screen on my voyager ii and havent used it in months. Thought maybe i could access it from my android phone but it cant find it. Ho can i reset the lock pattern
Esta é uma boa pergunta?
Pontuação 9
1 comentário
I FORGOT MY P[ROSCAN PLT7777G-Q PATTERN, PLEASE HELP ME. G.Cyrus
por Compartilhar
Adicionar um comentário
7 respostas
Solução escolhida
#1 Make sure tablet is powered off.
#2 Hold down Volume + button and Power button at same time.
  1. 3 When screen comes on let go of Power button.
  2. 4 When the large Android shows on screen let go of Volume + button.
  3. 5 Use Volume – button to scroll to Wipe Data/ Factory Reset
  4. 6 Tap Power button to select.
  5. 7 Use Volume – button to scroll to Yes.
  6. 8 Tap Power button to select.
  7. 9 Tap Power button to select Reboot System Now.
Esta resposta foi útil?
Pontuação 14
10 comentários:
Thanks Justin. Just an issue now with a laggy touchscreen. But i'm in. Thx again
por Compartilhar
i for got my password a week ago and this really helped me thx
por Compartilhar
Thanks by little cousin is able to play now my cousin the little cousins mom got from a friend who forgot the pattern lock in 12 am my big cousin is happy thx again
por Compartilhar
Thanks Justin, you are awesome! Now I can swap this tablet for my phone with my grandson! Yayyy!
por Compartilhar
Oh my goodness... THANK YOU!!!!
por Compartilhar
Exibir mais 5 comentários
this solution will reset your device. Which is the only way to unlock it
Pontuação 4
1 comentário:
Thanks for the reply. Worked like a charm
por Compartilhar
I still can't get the pattern lock off I've factory data reset the %#*@ thing and re booted t he system and its still locked does anyone have any suggestions please help
Pontuação 2
4 comentários:
I am having the same issue. Factory reset multiple times and still asks for the pattern to access the tablet. How do we get passed this?
por Compartilhar
I am having the same problem. Please help!! Why want the pattern change??
por Compartilhar
I am having the same issue. I have reset it multiple times and its still locked. Please help
por Compartilhar
Same here. No one seems to know what they're talking about.
por Compartilhar
Hi the only way to get past the lock screen is to reset the device back to factory in the recovery menu of the device. You should try to power it off then hold the down button and power button this should take you into recovery. From there you should scroll with the volume buttons and wipe/ factory data reset the device then reboot.
Pontuação 1
thanx……You made me feel like I knew what I was doing….
Pontuação 1
Yes! It worked. Thank you
Pontuação 0
I did this on an RCA Voyager 3 tablet, and it still looks for the Google account it had previously, please help!
Pontuação 0
Adicionar a sua resposta
Dale Reese será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 57
Ao todo: 19,347
