Ir para o conteúdo principal
Repair guides and support for electric and gas powered high pressure sprayers, sometimes known as power washers.
36 Perguntas Visualizar todos
Where can I get a CleanForce CF1800 HD repair manual?
Where can I get a CleanGorce CF1800 HD repair manual?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
There is none. I had to trash mine and buy another. I believe my unit had a bad internal termistor because it would cut off like it was overheating after only a brief use, then allow me to restart after several minutes. This time I went with a 2000 psi RYOBI from Home Depot.
Esta resposta foi útil?
Pontuação 0
1 comentário:
I had the exact problem you mentioned. I finally did the same thing you did. I trashed the CleanForce and replaced it with a different washer. Thank you for your response.
por
Adicionar a sua resposta
Donald Donald será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 17
Duração total: 488
