Ir para o conteúdo principal
LTE-enabled variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
46 Perguntas Visualizar todos
How can I get the back piece of the Ipad (5th Generation)
I bought a case and it had a sticky thing that kept the Ipad in place. I took it off because after 1 year of use the iPad wasn’t sticking to the case. When I removed the case the sticky things was on the back of my Ipad and wouldn't come off. I need the back piece if the Ipad.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
I guess what's left on the back of your housing is some kind of adhesive that might be removed one way or the other. Some adhesives are water based, others solvent based..depending on the solvent it might be melted by alcohol, isopropyl alcohol, turpentine or the likes. You might be better off trying various solvents until you cross the right one, less expensive and time consuming, replacing the housing takes hours let alone the risk of damaging something in the process. A mild heat could help in the task.
Esta resposta foi útil?
Pontuação 4
Adicionar a sua resposta
Jai Kamparachad será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 71
