Ir para o conteúdo principal
The Toshiba 40PB200 is a 40-inch flatscreen television in the PB200 series. It was released in 2012.
34 Perguntas Visualizar todos
Was watching it then picture went out but have perfect sound. .Turned
I have a 47" Toshiba smart LED t.v. and was watching it then picture went out the sound is perfect. I turned it off and on and did not work so I unplugged everything for half hour plugged back in and still no picture?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
'''++Barbara Martin++'''  let us know the exact model number for your TV. Since you have sound but no pictures it is possible that your backlight has failed. In a darkened room turn you rTV on and to a channel that you know is on the air. Then shine a flashlight at an angle against the screen, see if you can make out silhouettes etc. Then you will have to remove the back off your TV and take a look at all the boards and wiring. check for obvious damage like blown leaky caps etc. Post some images of your boards with your question so that we can see what you see. Use this guide Adicionar imagens a uma pergunta já existente for that.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Barbara Martin será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 70
