steps for wi-fi ribbon cable replacement
Does anyone know where I can find illustrated instructions or a video showing how to replace a wi-fi ribbon cable including how to install the conductive tape?
Esta é uma boa pergunta?
Jose check this answer Wifi flex cable attachment question I believe it will also answer all of your questions. Here is a link to a video that may help you to. Good Luck and let us know if this worked for you.
Esta resposta foi útil?
This instructions do help some but I would still like to see how solder is applied to each contact on the ribbon cable. I did it that way for a dock connector and it worked fine, but the ribbon's contacts are much thinner and closer together.
you can acquire the adhesive tape on ebay if you search seller Wztahotshot08 or the link with the best deal, i.e 2x 9"in strips
http://cgi.ebay.com/3M-9703-Conductive-A...
There are all different sizes from 6-9 in strips
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 2,036
